"front caliper pistons" von haydenvn
haydenvn am 26.10.2020 - 09:41
does anyone know of another bike that has the same pistons for the front caliper. i have a spare but want to rebuild the other. I have seals but the pistons were stuck and were damaged trying to remove them. none available at normal sourc
Spitzmaus am 26.10.2020 - 10:01
Good Morning,
pistons and seals are 38 & 34 mm if I remember. the 4 bigger ones are FZR600 1990 & the smaller 2 from RD350 are the equivalents.
The O-ring for the two halves is a standard one, nothing special.
rear brakes pstons are 43 mm.
MOTORCYCLE PRODUCTS sell the seals in the UK. If you fill in for the front in the search field brake seal 34mm or brake seal 38mm. for the rear fill in the make and model of the YAMAHA GTS you'll see the fitting seals and piston sets for the rear.
[Dieser Beitrag wurde am 26.10.2020 - 12:02 von Spitzmaus aktualisiert]
haydenvn am 26.10.2020 - 11:34
thankyou very much for info.
GTSunterwegs am 06.12.2020 - 13:42
"Spitzmaus schrieb
Good Morning,
MOTORCYCLE PRODUCTS sell the seals in the UK. If you fill in for the front in the search field brake seal 34mm or brake seal 38mm. for the rear fill in the make and model of the YAMAHA GTS you'll see the fitting seals and piston sets for the rear."
Hallo Rob, habe ich das dann richtig verstanden, dass das hier in meinem Anhang die passenden Dichtungen für den vorderen Bremssattel sind ??
Dichtung 34mm
Dichtung 38mm
[Dieser Beitrag wurde am 06.12.2020 - 13:52 von GTSunterwegs aktualisiert]
Arno am 08.12.2020 - 18:22
Ja das hast du richtig verstanden.
GTSunterwegs am 08.12.2020 - 20:02
Super, danke schön !
